GENERAL DESCRIPTION The DS600 is a ±0.5°C accurate analog-output temperature sensor. This accuracy is valid over its entire operating voltage range of 2.7V to 5.5V and the wide temperature range of -20°C to +100°C. The DS600 can also act as a thermostat, with userprogrammable trip points. A shutdown mode enables the DS600 to be placed in a low-power standby state. The DS600 is available in an 8-pin μSOP package. APPLICATIONS Cold-Junction Thermocouple Compensation Portable Medical Equipment Thermally Sensitive Systems that Require a High- Accuracy Analog-Output Temperature Sensor
