LM78L05M pdf datasheet
消耗积分:5 | 格式:rar | 大小:333 | 2008-12-11
赵辉
分享资料个
3-TERMINAL 0.15A POSITIVE VOLTAGE REGULATORS
This series of fixed-voltage monolithic integrated-circuit
voltage regulators is designed for a wide range of
applications.
These applications include on-card regulation for
elimination of noise and distribution problems associated
with single-point regulation.
In addition, they can be used with power-pass elements
to make high current voltage regulators.
Each of these regulators can deliver up to 150㎃ of output
current.
The internal limiting and thermal shutdown features of
these regulators make them essentially immune to overload.
When used as a replacement for a zener diode-resistor
combination, an effective improvement in output impedance
can be obtained together with lower-bias current.
评论(0)
发评论
下载排行榜
