RT9214 pdf datasheet (5V/12V S
消耗积分:5 | 格式:rar | 大小:333 | 2008-12-13
分享资料个
The RT9214 is a high efficiency synchronous buck PWM
controllers that generate logic-supply voltages in PC based
systems. These high performance , single output devices
include internal soft-start, frequency compensation
networks and integrates all of the control, output
adjustment, monitoring and protection functions into a
single package.
The device operating at fixed 300kHz frequency provides
an optimum compromise between efficiency, external
component size, and cost.
Adjustable over-current protection (OCP) monitors the
voltage drop across the RDS(ON) of the lower MOSFET for
synchronous buck PWM DC-DC controller. The overcurrent
function cycles the soft-start in 4-times hiccup
mode to provide fault protection, and in an always hiccup
mode for under-voltage protection.
评论(0)
发评论
下载排行榜
