The RT9209/A is a single power supply PWM DC-DC converter controller designed to drive N-MOSFET in a synchronous buck topology. The IC integrates the control, output adjustment, monitoring and protection functions into a small 8-pin package. The RT9209/A uses an internal compensated voltage mode PWM control for simple application design. An internal 0.8V reference allows the output voltage to be precisely regulated to low voltage requirement. A fixed 260kHz/ 400kHz oscillator reduce the component size for saving board area. The RT9209/A future a enable control pin to shutdown PWM switching and a 90% power good flag indicator. The FB pin under voltage detection function monitor the output short circuit which trigger a three time hiccup sequence to latch off the chip function.
