REF05 pdf datasheet (VOLTAGE R
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-18
分享资料个
The REF05 is a precision 5V voltage reference. The
drift is laser trimmed to 8.5ppm/°C max over the
extended industrial and military temperature range.
The REF05 provides a stable 5V output that can be
externally adjusted over a ±6% range with minimal
effect on temperature stability. REF05 operates from a
single supply with an input range of 8V to 40V with a
very low current drain of 1mA, and excellent temperature
stability due to an improved design. Excellent line
and load regulation, low noise, low power, and low
cost make the REF05 the best choice whenever a 5V
voltage reference is required. The REF05 is an ideal
choice for portable instrumentation, temperature transducers,
A/D and D/A converters, and digital voltmeter.
评论(0)
发评论
下载排行榜
