OPT209 pdf datasheet (PHOTODIO
消耗积分:2 | 格式:rar | 大小:333 | 2008-12-18
20615
分享资料个
The OPT209 is an opto-electronic integrated circuit
containing a photodiode and transimpedance
amplifier on a single dielectrically isolated chip. The
transimpedance amplifier consists of a precision FETinput
op amp and an on-chip metal film resistor. The
0.09 x 0.09 inch photodiode is operated at zero bias for
excellent linearity and low dark current.
The integrated combination of photodiode and
transimpedance amplifier on a single chip eliminates
the problems commonly encountered in discrete designs
such as leakage current errors, noise pick-up and
gain peaking due to stray capacitance.
The OPT209 operates over a wide supply range (±2.25
to ±18V) and supply current is only 400mA. It is
packaged in a transparent plastic 8-pin DIP, specified
for the 0°C to 70°C temperature range.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
