The OPA27/37 is an ultra-low noise, high precision monolithic operational amplifier. Laser-trimmed thin-film resistors provide excellent long-term voltage offset stability and allow superior voltage offset compared to common zener-zap techniques. A unique bias current cancellation circuit allows bias and offset current specifications to be met over the full –55°C to +125°C temperature range. The OPA27 is internally compensated for unity-gain stability. The decompensated OPA37 requires a closedloop gain ³ 5. The Burr-Brown OPA27/37 is an improved repla
