双馈电机定子电压有效控制是变速恒频发电机实现无冲击电流并网的关键,文章针对双馈电机定子电压控制进行研究,对比分析了空载并网方式、带负载并网方式以及“孤岛”并网方式,并出了各自的优缺点。
[关键词] 风力发电变速恒频双馈电机并网
Comparison and Analysis on Network SynchronizationModes of Several Kinds of
Variable Speed Constant FrequencyW ind Power Generator
L i J ian lin, Zhao D ongli, L i Yaxi, Xu Honghua
[ Abstract] The effective control on the voltage of double - feed generator stator is the key for the variable speed constant frequency generator
to realize the synchronized network without the impulse current. The author studies on the voltage control of the double feed generator stator,
compares and analyzes the mode for idle, on - load synchronized network and mode for " individual island" synchronization. He also gives the
advantages and disadvantages of allmodes.
[ Keywords] wind power generation; variable speed constant frequency; double feed generator; network synchronization
