HIP2500 pdf datasheet(Half Bri
消耗积分:5 | 格式:rar | 大小:333 | 2009-01-06
维生素B2
分享资料个
The HIP2500 is a high voltage integrated circuit (HVIC) optimized
to drive N-Channel MOS gated power devices in half bridge topologies.
It provides the necessary control for PWM motor drive,
power supply, and UPS applications. The SD pin allows external
shutdown of gate drive to both upper and lower gate outputs. Undervoltage
lockout will not allow gating when the bias voltage is too
low to drive the external switches into saturation.
The HIP2500IP is pin and function compatible to the International
Rectifier IR2110. The HIP2500 has superior ability to
accept negative voltages from the VS pin to the COM pin due to
forward recovery of the lower flyback diode.
The HIP2500IB is a SOIC or small outline IC form of the
HIP2500. The HIP2500IB drives high side and low side referenced
power switches just like the HIP2500IP.
The HIP2500IP1 is a 16 lead Plastic DIP form of the HIP2500.
Pins 4 and 5 removed from lead frame to provide extra creepage
and strike distances in high voltage applications.
Please see Application Note AN9010 for more information.
评论(0)
发评论
下载排行榜
