基于MIKROE-3436Temperature Sensing的参考设计
消耗积分:0 | 格式:pdf | 大小:60.54KB | 2021-01-14
370217
分享资料个
说明
  • MIKROE-3436, Temp&Hum 12 click is a smart environmental temperature and humidity sensor Click board, packed with features which allow easy and simple integration into any design that requires accurate and reliable humidity and temperature measurements. The capacitive-based sensor includes new integrated digital features and a heating element to dissipate condensation and moisture. This translates to a prolonged life of the Click board itself. Temp&Hum 12 click is a perfect solution for a wide range of applications that depend on accurate temperature and humidity readings. With its low power consumption and programmable interrupt requests capability, it is also a perfect choice for various temperature and relative humidity based IoT applications, smart thermostats and smart home assistants
主要特色
  • 输入信号幅度
    3.3 V
评论(0)
发评论
下载排行榜
