基于MIKROE-3425Temperature Sensing的参考设计
消耗积分:0 | 格式:pdf | 大小:79.1KB | 2021-01-09
分享资料个
说明
  • MIKROE-3425, Temp&Hum 5 click is a temperature and humidity sensing click board, packed with features that allow simple integration into any design. It can measure a wide range of temperature and relative humidity values with high accuracy. The Click board is equipped with the HIH6130 sensor, offering the complete measurement system onboard: capacitive humidity sensor, bandgap thermal sensor, signal processing, and the I2C communication interface. Featuring good reliability over time, high accuracy, and low hysteresis, it represents an ideal solution to be used in various temperature and humidity related applications
主要特色
  • 输入信号幅度
    3.3 | 5 V
评论(0)
发评论
下载排行榜
