HA-5002 pdf datasheet (110MHz,
消耗积分:3 | 格式:rar | 大小:223 | 2009-01-07
分享资料个
The HA-5002 is a monolithic, wideband, high slew rate, high
output current, buffer amplifier.
Utilizing the advantages of the Intersil D.I. technologies, the
HA-5002 current buffer offers 1300V/μs slew rate with
110MHz of bandwidth. The ±200mA output current capability
is enhanced by a 3Ω output impedance.
The monolithic HA-5002 will replace the hybrid LH0002 with
corresponding performance increases. These characteristics
range from the 3000kΩ input impedance to the increased
output voltage swing. Monolithic design technologies have
allowed a more precise buffer to be developed with more than
an order of magnitude smaller gain error.
The HA-5002 will provide many present hybrid users with a
higher degree of reliability and at the same time increase
overall circuit performance.
For the military grade product, refer to the HA-5002/883
datasheet.
评论(0)
发评论
下载排行榜
