HM-6508 pdf datasheet (1024 x
消耗积分:3 | 格式:rar | 大小:233 | 2009-01-09
名士流
分享资料个
The HM-6508 is a 1024 x 1 static CMOS RAM fabricated
using self-aligned silicon gate technology. Synchronous
circuit design techniques are employed to achieve high performance
and low power operation.
On-Chip latches are provided for address, allowing efficient
interfacing with microprocessor systems. The data output
buffers can be forced to a high impedance state for use in
expanded memory arrays.
The HM-6508 is a fully static RAM and may be maintained in
any state for an indefinite period of time. Data retention supply
voltage and supply current are guaranteed over temperature.
评论(0)
发评论
下载排行榜
