The ADALP2000 Parts Kit contains a large selection of components perfect for creating a wide variety of useful circuits and devices. Featuring a variety pf components from Analog Devices, the kit includes transistors, resistors, capacitors, diodes, sensors, and variety of useful ICs including op-amps, converters, and regulators.
We are on Rev B of the ADALP2000 parts kit, and its BIGGER and more COMPREHENSIVE than ever. Below is a complete rundown of the components that can be found within the kit.
A complete list and description of components is listed below.
It is possible that some inductors included in the ADALP2000 parts kit may have sustained some cosmetic impairments during shipping and handling. These inductors are 100% functional, and while the cosmetic issues does not look nice, it does not affect the electrical performance, and all devices meet their datasheet specifications.
| Picture | Part Number | Description | Link |
| AD22151 | Magnetic Field Sensor | ad22151 |
| AD5626 | 12-Bit Digital to Analog Converter | AD5626 |
| AD7920 | 12-Bit Analog to Digital Converter | AD7920 |
| AD8210 | Current Shunt Monitor | AD8210 |
| AD8226 | Instrumentation Amplifier | AD8226 |
| AD8542 | CMOS Rail to Rail Op Amp | AD8542 |
| ADP3300 | 3.3V, 50mA Linear Regulator(LDO) | ADP3300 |
| ADTL082 | JFET Op-Amp | ADTL082 |
| ADXL327 | 3-Axis Low-G Accelerometer | ADXL327 |
| LT3092 | Programmable Current Source | LT3092 |
| LTC1541 | Microppower Amp, Comparator, & Reference | LTC1541 |
| LTM8067 | Isolated DC-DC Converter | LTM8067 |
| HPH1-0190 | Hexa-Path Transformer | Datasheet |
| HPH1-1400 | Hexa-Path Transformer | Datasheet |
| SJ-43515TS-SMT-TR | TRRS Microphone In | Datasheet |
| ZX62D-B-5PA8(30) | Micro USB Connector | |
| AD584 | Programmable Voltage Reference | AD584 |
![]() | AD592 | Current Temperature Sensor | AD592 |
| AD654 | Voltage to Frequency Converter | AD654 |
| AD22100 | Voltage Temperature Sensor | AD22100 |
| AD8561 | Comparator | AD8561 |
| LT3080 | Adjustable 1.1A LDO | LT3080 |
| LTC1043 | Precision Switch-CAP Block | LTC1043 |
| LTC1054 | Switched-Capacitor Regulator | LT1054 |
| LTC1485 | Differential Bus Transceiver | LTC1485 |
| OP27 | Low Noise, Precision Op Amp | OP27 |
| OP37 | Precision Op Amp | OP37 |
| OP97 | Low Noise, Precision Op Amp | OP97 |
| OP482 | High Speed JFET Op Amp | OP482 |
| OP484 | Precision Rail to Rail Op Amp | OP484 |
| TMP01 | Temperature Controller | TMP01 |
| SN74HC04N | Hex Inverter | Datasheet |
| SN74HC08N | Quad AND Gate | Datasheet |
| SN74HC32N | Quad OR Gate | Datasheet |
| SN74HC273N | Octal Flip Flop | Datasheet |
| Solderless Breadboard | Solderless Breadboard | |
| Jumper Wires | Male to Male Jumper Wires | |
| Screwdriver | Flathead Screwdriver | |
| HCM9765-P11-453 | Microphone | Datasheet |
| Speaker | 8 Ω Speaker | |
| B57164K103J | 10 kΩ Thermistor 5mm lead coated disk | Datasheet |
| SQP10AJB-6R2 | 6.2 Ω 10W Power Resistor Axial Cement Link | Datasheet |
| * 3386C-1-502LF * 3386C-1-103LF * 3386C-1-503LF | * Single Turn 5 kΩ Potentiometer * Single Turn 10 kΩ Potentiometer * Single Turn 50 kΩ Potentiometer | Datasheet |
![]() | 2N3904 | NPN General Purpose Transistor TO-92 Link Marking: 2N3904 | Datasheet |
| 2N3906 | PNP General Purpose Transistor TO-92 Link Marking: 2N3906 | Datasheet |
| IRF510 | N-Channel MOSFET 100V TO-220 Link Marking: IRF510 | Datasheet |
| TIP31CFS | NPN Epitaxial Transistor TO-220 Link Marking: TIP31 | Datasheet |
| TIP32CFS | PNP Epitaxial Transisitor TO-220 Link Marking: TIP32 | Datasheet |
| ZVN2110A | N-Channel Enhancement FET TO-92 Link Marking: ZVN211 | Datasheet |
| ZVN3310 | N-Channel Enhancement Transistor TO-92 Link Marking: ZVN211 | Datasheet |
| ZVP2110A | P-Channel Enhancement FET TO-92 Link Marking: ZVP211 | Datasheet |
| various LEDs (red, yellow, Green) | T-1 3/4 Link | |
| QED-123 | Infrared LED T-1 3/4 | Datasheet |
| QSD123 | Infrared Photo Transistor T-1 | Datasheet |
| 1N3064 | Small Signal Diode DO-35 Link | Datasheet |
| 1N4001 | 50V General Purpose Rectifier DO-204 Link | Datasheet |
| 1N4735 (or 1N4729) | 6.2V (or 3.6V) Zener Diode DO-41 Link | Datasheet |
| Note that the diodes can be difficult to identify. This circuit can be used to identify the Zener diode and determine whether it is the 3.6V or 6.2V model. | | Set V-/V+ to -5V/+5V (or use a benchtop supply set to 10V.) The Zener diode will read ~6.2 (or ~3.6V) from 1- to 1+, a silicon or Schottky diode will read 10V. | |
| 1N914 | Small Signal Diode DO-35 Link | Datasheet |
| OP999 | Photodiode T-1¾ | Datasheet |
| * RFB0807-1R0L * RFB0807-100L * RFB0807-101L * RFB0807-102L * RFB0807-103L | * 1uH Inductor 5mm radial Link * 10uH Inductor 5mm radial Link * 100uH Inductor 5mm radial Link * 1mH Inductor 5mm radial Link * 10m Inductor 5mm radial Link | Datasheet |
| * 1.1 Ω 1/8W axial Resistor * 10 Ω 1/8W axial Resistor * 47 Ω 1/8W axial Resistor * 68 Ω 1/8W axial Resistor * 100 Ω 1/8W axial Resistor * 470 Ω 1/8W axial Resistor * 1 kΩ 1/8W axial Resistor * 1.5 kΩ 1/8W axial Resistor * 2.2 kΩ 1/8W axial Resistor * 4.7 kΩ 1/8W axial Resistor * 6.8 kΩ 1/8W axial Resistor * 10 kΩ 1/8W axial Resistor * 20 kΩ 1/8W axial Resistor * 47 kΩ 1/8W axial Resistor * 68 kΩ 1/8W axial Resistor * 100 kΩ 1/8W axial Resistor * 200 kΩ 1/8W axial Resistor * 470 kΩ 1/8W axial Resistor * 1 MΩ 1/8W axial Resistor * 5 MΩ 1/8W axial Resistor | Resistors Link (including color code) Axial Carbon Comp. | |
| * 39pF Ceramic Capacitor Disc * 100pF Ceramic Capacitor Disc * 0.001 μF Ceramic Capacitor Disc * 0.0047 μF Ceramic Capacitor Disc * 0.01 μF Ceramic Capacitor Disc * 0.047 μF Ceramic Capacitor Disc * 0.1 μF Ceramic Capacitor Disc * 1 μF Electrolytic Capacitor Can * 4.7 μF Electrolytic Capacitor Can * 10 μF Electrolytic Capacitor Can * 22 μF Electrolytic Capacitor Can * 47 μF Electrolytic Capacitor Can * 220 μF Electrolytic Capacitor Can | * Link Marking: 39 * Link Marking: 101 * Link Marking: 102 * Link Marking: 472 * Link Marking: 103 * Link Marking: 473 * Link Marking: 104 * Link Marking: 1 μF * Link Marking: 4.7 μF * Link Marking: 10 μF * Link Marking: 22 μF * Link Marking: 47 μF * Link Marking: 220 μF |
