ISL22316WMUEP pdf datasheet (L
消耗积分:3 | 格式:rar | 大小:433 | 2009-01-19
张磊
分享资料个
Low Noise, Low Power I2C® Bus, 128 Taps
The ISL22316WMUEP integrates a single digitally controlled
potentiometer (DCP) and non-volatile memory on a
monolithic CMOS integrated circuit.
The digitally controlled potentiometer is implemented with a
combination of resistor elements and CMOS switches. The
position of the wipers are controlled by the user through the
I2C bus interface. The potentiometer has an associated
volatile Wiper Register (WR) and a non-volatile Initial Value
Register (IVR) that can be directly written to and read by the
user. The contents of the WR controls the position of the
wiper. At power-up, the device recalls the contents of the
DCP’s IVR to the WR.
The DCP can be used as a three-terminal potentiometer or
as a two-terminal variable resistor in a wide variety of
applications including control, parameter adjustments and
signal processing.
Device Information
The specifications for an Enhanced Product (EP) device are
defined in a Vendor Item Drawing (VID), which is controlled
by the Defense Supply Center in Columbus (DSCC).
“Hot-links” to the applicable VID and other supporting
application information are provided on our website.
评论(0)
发评论
下载排行榜
