The 5962-0721301QXC, 5962-0721302QXC and 5962-0721303QYC are fully DSCC SMD compliant parts and the SMD data sheets are available on the DSCC website (http://www.elecfans.com/ programs/specfind/default.asp). The 5962-0721301QXC is electrically equivalent to the EL8202, the 5962-0721302QXC is electrically equivalent to the EL8203, and the 5962-0721303QYC is electrically equivalent to the EL8403. Reference equivalent “EL” data sheet for additional information. These parts are dual and quad rail-torail amplifiers with a -3dB bandwidth of 500MHz and slew rate of 600V/μs. Running off a low supply current of 13.5mA per channel, the 5962-0721301QXC, 5962-0721302QXC, and 5962- 0721303QYC also feature inputs that go to 0.15V below the VS- rail. The 5962-0721301QXC and 5962-0721302QXC are dual channel amplifiers. The 5962-0721303QYC is a quad channel amplifier. The 5962-0721301QXC includes a fast-acting disable/power-down circuit with a 25ns disable and a 200ns enable, the 5962-0721301QXC is ideal for multiplexing applications.
