ISL55016 pdf datasheet (MMIC S
消耗积分:3 | 格式:rar | 大小:333 | 2009-02-10
杨福林
分享资料个
MMIC Silicon Bipolar Differential Amplifier
The ISL55016 is a high performance gain block which can
match a 75Ω single-ended source to a 100Ω differential
load. This feature makes the ISL55016 ideal for a wide
range of general-purpose applications such as Satellite TV.
The ISL55016 can be used as single-ended to differential
converter and eliminates the need for an external balun
structure.
评论(0)
发评论
下载排行榜
