Typical Application Circuit for LT3089IFE Linear Regulator for Adding Soft-Start. The LT3089 is an 800mA low dropout linear regulator designed for Rugged Industrial Applications. Key features of the IC are the extended safe operating area (SOA), output current monitor, temperature monitor and programmable current limit. The LT3089 can be paralleled for higher output current or heat spreading
