The RT8450 is a current mode PWM regulator for LED driving applications. With an 1.5A switch on board and wide input (4.5V to 40V) and/or output (up to 60V)ranges the RT8450 can operate in any of the three common topologies : Buck, Boost or Buck-Boost. With a 1MHz operating frequency, the external PWM inductor and input/output capacitors can all be small. High efficiency is achieved with a 190mV current sensing. Dimming can be either analog or PWM digital, an unique built-in clampping comparator and filtering resistor allow easy low noise analog dimming conversion from PWM signal with only one external capacitor. The RT8450 is available in a TSSOP-16 (Exposed Pad) and WDFN-12L 3x3 power packages.
