VS1000 pdf datasheet (Ogg Vorb
消耗积分:3 | 格式:rar | 大小:333 | 2009-02-11
胡秋阳
分享资料个
VS1000 is a single-chip Ogg Vorbis (license-free
audio codec) player. VS1000 contains a high-performance
low-power DSP core VS DSP4, NAND
FLASH interface, Full Speed USB port, general
purpose I/O pins, SPI, UART, as well as a highquality
variable-sample-rate stereo DAC, and an
earphone amplifier and a common voltage buffer.
VS1000 firmware implements a default player that
reads and plays files from the NAND FLASH.
The player can be customized or replaced by using
boot from NAND FLASH.
评论(0)
发评论
下载排行榜
