基于EASYKIT DCDC直流到直流单输出电源的参考设计
消耗积分:2 | 格式:pdf | 大小:3.74MB | 2021-07-31
李伟
分享资料个
说明
  • EASYKIT DCDC, Evaluation Board for the HV to LV DC/DC-Converter Evaluation Kit with Easy Automotive Module. The Evaluation Kit EASYKIT DCDC was developed to support customers during their first steps in designing applications with the Easy Automotive H-Bridge power module. This Easy Module contains High Speed IGBT3 and Rapid Diode and is e.g. well suited for HV to LV DC/DC-converters in phase shift full bridge zero voltage transition (ZVT) DC/DC-converters up to 100 kHz and 3 kW
主要特色
  • Conversion Type
    DC to DC
  • Input Voltage
    160 to 350 V
  • Output Voltage
    14 V
  • Output Current
    170 A
  • Efficiency
    93 %
  • Topology
    Full Bridge- Phase Shifted
评论(0)
发评论
下载排行榜
