MAX2141 pdf datasheet (Low-Pow
消耗积分:3 | 格式:rar | 大小:333 | 2009-02-15
分享资料个
The MAX2141 complete low-power receiver is designed for XM satellite radio applications. To form a complete XM radio, the MAX2141 requires only an active antenna module, a crystal, and a SAW filter. The small number of external components needed makes the MAX2141 platform the lowest cost and the smallest wideband receiver solution available.
The receiver includes a self-contained RF AGC loop and IF AGC loop, effectively providing a total dynamic range in excess of 92dB. Channel selectivity is achieved by the SAW filter and by the on-chip lowpass filters. An integrated fractional-N synthesizer allows fine frequency step, making possible the implementation of a software AFC loop. Additionally, a reference buffer is provided for driving a baseband controller.
An I2C bus-compatible interface programs the MAX2141, providing features such as programmable gains, variable-bandwidth lowpass filter tuning, and various power-down modes.
The MAX2141 is Maxim's 2nd-generation device for XM satellite radio applications. It is a drop-in replacement for the 1st-generation MAX2140. While significantly reducing power dissipation, the MAX2141 adds an optional closed-loop IF power control, standby mode, enhanced reference buffer, and improved RF gain-control accuracy.
The MAX2141 is rated to operate over the -40°C to +85°C extended temperature range and is available in a 7mm x 7mm, 44-pin thin QFN package.
  • Pin Compatible with the MAX2140
  • Self-Contained RF AGC Loop
  • Self-Contained IF AGC Loop
  • +2.85V to +3.6V Operating Voltage Range
  • Complete Integrated Frequency Generation
  • Overcurrent Protection for External LNA
  • Low-Power Standby Mode
  • Very Small 44-Pin TQFN Package
  • 250mW Power Dissipation (at VCC = +3.0V)
  • 声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容侵权或者其他违规问题,请联系本站处理。 举报投诉
    评论(0)
    发评论
    下载排行榜
