基于X-NUCLEO-IDS01A4射频收发器的参考设计
消耗积分:2 | 格式:pdf | 大小:234.62KB | 2021-09-10
479809
分享资料个
说明
  • X-NUCLEO-IDS01A4, Evaluation Board based on the SPIRIT1 RF module SPSGRF-868 expansion of STM32 Nucleo boards. The SPSGRF-868 module operates in the 868 MHz ISM band is ETSI certified. Identification of the operating frequency of the X-NUCLEO-IDS01Ax (x=4 or 5) is performed through two resistors (R14 and R15). It is compatible with the MORPHO and Arduino UNO R3 connector layout. The X-NUCLEO-IDS01A4 interfaces with the STM32 microcontroller via SPI connections and GPIO pins. The user can change some of the GPIOs by mounting or removing the resistors
主要特色
  • Operating Frequency
    868 MHz
评论(0)
发评论
下载排行榜
