MTK1389的DVD方案程序C语言源代码,自已根据需要修改界面什么的就可以成自已的产了。MTK1389 the DVD program source code, customers can modify according to their own needs some of what the interface can be used used, with the schematic I uploaded (MTK1389 schematic) SACL1389L it.
#define _C_ADAC_
#include "general.h"
#pragma NOAREGS
#ifndef _NPADAC_
BYTE xdata _bAudioSample; // 0->50k, 1->100k, 2->200k
#endif
#ifdef _PCM1723_
extern void vADAC1723Setting(WORD wValue) large;
#endif
#ifdef _PCM1604_
extern BYTE bDA1604Read(BYTE bIndex) large;
extern void vDA1604Write(BYTE bIndex, BYTE bValue) large;
#endif
#if (defined(_PCM1742_) || defined(_WM8746_) || defined(_AK4357_) || defined(_AK4356_) || defined(_AK4382_))
extern void vADACWrite(BYTE bRegAddr, BYTE bValue) large;
#endif
#if (defined(_AV2188_) || defined(_AV2388_))
全部3条评论
! 收起回复
