ADC 数据采集发送到 pc
消耗积分:5 | 格式:pdf | 大小:0.09 MB | 2021-11-30
五斤麻辣油
分享资料个
#include “ioCC2530.h”#include typedef unsigned int uint;typedef unsigned char uchar;uchar count = 0;void Init_Clock_32MHz();void Init_Uart0();void UART0_Send_Byte(unsigned char dat);void UART0_Send_String(unsigned char *str);void In
评论(0)
发评论
下载排行榜
