database-doc-generator
数据库文档生成器
该工具根据给定的链接生成数据库文档,如果你嫌powerdesigner太重,那么可以试试该工具。
你可以下载release包来或者下载源代码来使用。
如果使用源代码,需要先克隆该项目后运行mvn package打包,然后运行发布包中bin/start.bat
运行程序后按照下面提示输入对应数据库参数:
input mysql host: 127.0.0.1 input mysql port: 3306 input database name: guns-lite input mysql username: root input mysql password: root
输入完成后回车,即可生成数据库文档目录${dbname}-doc,目录中文档以markdown文件为载体:
确保安装了gitbook后,进入上述文件目录的命令行窗口运行:gitbook serve
E:\\database-doc-generator-20181006100721\guns-lite-doc>gitbook serve openssl config failed: error:02001003:system library:fopen:No such process Live reload server started on port: 35729 Press CTRL+C to quit ... info: 7 plugins are installed info: loading plugin "livereload"... OK info: loading plugin "highlight"... OK info: loading plugin "search"... OK info: loading plugin "lunr"... OK info: loading plugin "sharing"... OK info: loading plugin "fontsettings"... OK info: loading plugin "theme-default"... OK info: found 15 pages info: found 0 asset files info: >> generation finished with success in 1.6s ! Starting server ... Serving book on http://localhost:4000
