MPMCQueue有界多生产者多用户无锁队列
消耗积分:0 | 格式:zip | 大小:0.05 MB | 2022-06-22
久醉不醒
分享资料个
授权协议 MIT
开发语言 C/C++
操作系统 跨平台
软件类型 开源软件
所属分类 程序开发常用工具包
软件简介
MPMCQueue 是一个用C ++ 11编写的有界多生产者多用户无锁队列。
示例代码
MPMCQueue q(10);
auto t1 = std::thread([&] {
  int v;
  q.pop(v);
  std::cout << "t1 " << v << "\n";
auto t2 = std::thread([&] {
  int v;
  q.pop(v);
  std::cout << "t2 " << v << "\n";
q.push(1);
q.push(2);
t1.join();
t2.join();
使用
  • MPMCQueue(size_t capacity);
    Constructs a new MPMCQueue holding items of type T with capacity capacity.
  • void emplace(Args &&... args);
    Enqueue an item using inplace construction. Blocks if queue is full.
  • bool try_emplace(Args &&... args);
    Try to enqueue an item using inplace construction. Returns true on success and false if queue is full.
  • bool push(const T &v);
    Enqueue an item using copy construction. Blocks if queue is full.
  • template bool push(P &&v);
    Enqueue an item using move construction. Participates in overload resolution only if std::is_nothrow_constructible::value == true. Blocks if queue is full.
  • bool try_push(const T &v);
    Try to enqueue an item using copy construction. Returns true on success and false if queue is full.
  • template bool try_push(P &&v);
    Try to enqueue an item using move construction. Participates in overload resolution only if std::is_nothrow_constructible::value == true. Returns true on success and false if queue is full.
  • void pop(T &v);
    Dequeue an item by copying or moving the item into v. Blocks if queue is empty.
  • bool try_pop(T &v);
    Try to dequeue an item by copying or moving the item into v. Return true on sucess and false if the queue is empty.
所有操作都是线程安全的,除了构造和析构函数。
实际原理
Enqeue:
  1. Acquire next write ticket from head.
  2. Wait for our turn (2 * (ticket / capacity)) to write slot (ticket % capacity).
  3. Set turn = turn + 1 to inform the readers we are done writing.
Dequeue:
  1. Acquire next read ticket from tail.
  2. Wait for our turn (2 * (ticket / capacity) + 1) to read slot (ticket % capacity).
  3. Set turn = turn + 1 to inform the writers we are done reading.
参考资料:
评论(0)
发评论
下载排行榜
