PIC单片机的RS232通讯程序
消耗积分:10 | 格式:rar | 大小:84 KB | 2011-02-25
tr12345
分享资料个
Digitemp Jr. is a device that is designed to measure
and report ambient temperature. When connected to
an RS-232 port on any PC, it will periodically measure
and report in ASCII form the ambient temperature in
degrees Celsius. These temperature readings can be
monitored with any terminal program. If the terminal
program supports capture to disk, the temperature
readings can be saved to disk for further analysis with
a spreadsheet program or other data analysis tool. The
simple ASCII output format of Digitemp Jr. makes it relatively
easy to write custom software for receiving,
recording, and analyzing ambient temperature data.
Best of all, Digitemp Jr. requires no external power supplies
or batteries. It is powered directly by the RS-232
port.
评论(3)
发评论
海川 2013-09-15
0 回复 举报
初学PIC 下载一个代码看看 收起回复
hu198812 2011-02-27
3 回复 举报
学习中 收起回复
全部评论
下载排行榜
全部3条评论
