光发射机APC及ATC电路研究与分析
消耗积分:10 | 格式:rar | 大小:1.11 MB | 2011-03-05
分享资料个
 为保障光发射机具有良好的工作环境和稳定的发送光功率,设计完成JAPC和ATC两个电路的应用,在10 GB/s的传输速率下获得良好效果,通过主用与备用设备的交替使用和及时更换LD和 PD元件使光发射机长期稳定可靠工作。随着SDH同步数字传输体系要求的不断提高,光发射机速率的提高成为急需解决的问题,可以使用WDM技术提高传输能力。
Abstract:
 To protect optical transmitter with a good working environment and a stable optical power sent, this paper designed and accomplished the APC and ATC two circuits, which obtained good results in 10GB/s transfer rate. By alternately using main and spare equipment and timely replacing LD and PD devices, the optical transmitter enable to work stably and reliably in a long-term. With the increasing requirements of SDH synchronous digital transmission system, the improvement of the optical transmitter rate becomes an urgent issue,which could use WDM technology to improve transmission capacity.
评论(0)
发评论
下载排行榜
