为解决电致变色器件的颜色变化受外界环境颜色控制的问题,设计了一种基于单片机的便携式颜色自适应识别电路。与传统颜色识别电路相比较,该电路利用数字式的颜色传感器来获取外界环境颜色,产生的数字颜色信号易于单片机进行处理。在电路中,下位机部分主要负责获取电致变色器件变色参数及控制电致变色器件的颜色变化;而上位机部分主要负责把下位机获取的电致变色器件变色参数进行电压到颜色的曲线拟合,并通过蓝牙通信把拟合曲线参数传递给下位机。结果表明,该电路能自动根据环境颜色提供-4~4 V范围步进为0.1 V的电压来驱动电致变色器件的颜色显示,与传统的颜色识别电路设计相比,识别的精度和速度都得到了明显改善。
Abstract:
In this paper, a portable adaptive circuit for color identification(PACCI) based on MCU was designed. Compared to the traditional color identification circuit, the PACCI adopts digital sensor to detect the color data from external environment and further generate digital color data, which can be processed easily by MCU. In PACCI, the slave is mainly responsible for detecting the color parameters of the corresponding elcreochromic device and further driving it. For the master, which is mainly responsible for the color curve fitting based on the parameters of the electrochromic device, and transmits the fitting parameters to the slave through the bluetooth device. The results show that the PACCI can provide the basis voltage range from -4V to 4V automatically based on the colors of external environment with step as 0.1V to drive the corresponding electrochromic device. Compared to the traditional color recognition circuit, the recognition accuracy and speed of PACCI have been improved significantly.
全部1条评论
很好不错,我做做看 收起回复
