DS3502 pdf datasheet (High-Vol
消耗积分:3 | 格式:rar | 大小:333 | 2009-03-23
小峰
分享资料个
The DS3502 is a 7-bit, nonvolatile (NV) digital potentiometer featuring an output voltage range of up to 15.5V. Programming is accomplished by an I²C-compatible interface, which can operate at speeds of up to 400kHz. External voltages are applied at the RL and RH inputs to define the lowest and highest potentiometer outputs.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
