Atmel AT89C系列单片机电路板设计指南
消耗积分:0 | 格式:pdf | 大小:7.22 MB | 2011-03-23
dplion
分享资料个
Designing Boards with Atmel AT89C51,AT89C52, AT89C1051, and AT89C2051 for Writing Flash at In-Circuit Test.
Recent improvements in chips and testers have made it possible for the tester to begin taking over the role tradi-tionally assigned to the PROM program-mer. Instead of having a PROM pro- grammer write nonvolatile memories before assembling the board, the in-cir- cuit tester writes them during in-circuit testing operations. Many Teradyne Z18- series testers are now in use loading code into nonvolatile memories, micro- controllers and in-circuit programmable logic devices. The purpose of this note is to explain how the Z18 approaches the writing task for Atmel AT89C series IC’s, so that designers of boards using these chips can get the best results.
评论(26)
发评论
汉官威仪 2015-11-15
0 回复 举报
学习学习 收起回复
861765213 2015-10-03
0 回复 举报
下载了就一定要顶!! 收起回复
全部评论
下载排行榜
全部26条评论
