将 Arduino Nano 连接到IO 扩展器并使用以下代码对其进行编程。6 针接头是软件串行调试端口,最终安装时不需要。
确保更改 ONEWIRE_TO_I2C_ROM 定义的地址以匹配您的1-Wire 到 I2C地址。
/* IO Expander
* Basement/Crawlspace Ventilation System v1.1
#include
#include
#include
#include "IOExpander.h"
#define FAHRENHEIT
#define ONEWIRE_TO_I2C_ROM "i4s71"
#define INIT_OLED "st13;si;sc;sd"
#define HUMIDITY_SENSOR_INSIDE "s6t1"
#define HUMIDITY_SENSOR_OUTSIDE "s8t1"
#define FAN_ON "r1o"
#define FAN_OFF "r1f"
#define ABSOLUTE_DELTA_FAN_ON 1 // Fan on if absolute humidity delta of inside >= outside
#define ABSOLUTE_DELTA_FAN_OFF 0.5 // Fan off if absolute humidity delta of inside <= outside
#define OUTSIDE_RELATIVE_FAN_ON 88 // Fan on if outside relative humidity is <= %
#define OUTSIDE_RELATIVE_FAN_OFF 90 // Fan off if outside relative humidity is >= %
#define MINIMUM_TEMPERATURE 15 // Cycle vent on/off if outside temperature <= 15C/59F
#define FAN_ON_TIME (20*60*1000L) // 20 min
#define FAN_OFF_TIME (20*60*1000L) // 20 min
//#define SERIAL_DEBUG
#define SERIAL_TIMEOUT 5000 // 5 sec delay between DHT22 reads
#ifdef SERIAL_DEBUG
SoftwareSerial swSerial(8,7);
#endif
struct HS {
float temp;
float relative;
float absolute;
bool error;
int led = 13;
bool init_oled = true;
long ontime, offtime;
#ifdef FAHRENHEIT
#define C2F(temp) CelsiusToFahrenheit(temp)
float CelsiusToFahrenheit(float celsius)
return ((celsius*9)/5)+32;
#else
#define C2F(temp) (temp)
#endif
void SerialPrint(const char* str, float decimal, char error)
Serial.print(str);
if (error) Serial.print(F("NA"));
else Serial.print(decimal, 1);
float DewPoint(float temp, float humidity)
float t = (17.625 * temp) / (243.04 + temp);
float l = log(humidity/100);
float b = l + t;
// Use the August-Roche-Magnus approximation
return (243.04*b)/(17.625-b);
#define MOLAR_MASS_OF_WATER 18.01534
#define UNIVERSAL_GAS_CONSTANT 8.21447215
float AbsoluteHumidity(float temp, float relative)
//taken from https://carnotcycle.wordpress.com/2012/08/04/how-to-convert-relative-hu midity-to-absolute-humidity/
//precision is about 0.1°C in range -30 to 35°C
//August-Roche-Magnus 6.1094 exp(17.625 x T)/(T + 243.04)
//Buck (1981) 6.1121 exp(17.502 x T)/(T + 240.97)
//reference https://www.eas.ualberta.ca/jdwilson/EAS372_13/Vomel_CIRES_satvpformulae.html // Use Buck (1981)
return (6.1121 * pow(2.718281828, (17.67 * temp) / (temp + 243.5)) * relative * MOLAR_MASS_OF_WATER) / ((273.15 + temp) * UNIVERSAL_GAS_CONSTANT);
void ReadHumiditySensor(HS* hs)
SerialCmd("sr");
if (SerialReadFloat(&hs->temp) &&
SerialReadFloat(&hs->relative)) {
//hs->dewpoint = DewPoint(hs->temp, hs->relative);
hs->absolute = AbsoluteHumidity(hs->temp, hs->relative);
hs->error = false;
else hs->error = true;
SerialReadUntilDone();
void setup() {
Serial.begin(115200);
#ifdef SERIAL_DEBUG
swSerial.begin(115200);
//swSerialEcho = &swSerial;
#endif
pinMode(led, OUTPUT);
wdt_enable(WDTO_8S);
offtime = millis() - FAN_OFF_TIME;
void loop() {
HS inside, outside;
static bool fan = false;
static bool cycle = false;
static long last_time = -(60L * 1000L);
Serial.println();
if (SerialReadUntilDone()) {
// Read the humidity sensors only once a minute or they will self heat if read too quickly
if (millis() - last_time > 60L * 1000L)
if (SerialCmdDone(HUMIDITY_SENSOR_INSIDE))
ReadHumiditySensor(&inside);
if (SerialCmdDone(HUMIDITY_SENSOR_OUTSIDE))
ReadHumiditySensor(&outside);
if (inside.error || outside.error) fan = false;
else {
if (fan) {
if (outside.relative >= OUTSIDE_RELATIVE_FAN_OFF || inside.absolute - outside.absolute <= ABSOLUTE_DELTA_FAN_OFF)
cycle = fan = false;
else {
if (cycle && outside.temp <= MINIMUM_TEMPERATURE &&
millis() - ontime > FAN_ON_TIME) fan = false;
if (!fan) offtime = millis();
else {
if (outside.relative <= OUTSIDE_RELATIVE_FAN_ON && inside.absolute - outside.absolute >= ABSOLUTE_DELTA_FAN_ON)
cycle = fan = true;
if (cycle && outside.temp <= MINIMUM_TEMPERATURE)
fan = (millis() - offtime > FAN_OFF_TIME) ? true : false;
if (fan) ontime = millis();
if (fan) SerialCmdDone(FAN_ON);
else SerialCmdDone(FAN_OFF);
if (SerialCmdNoError(ONEWIRE_TO_I2C_ROM)) {
if (init_oled) {
SerialCmdDone(INIT_OLED);
init_oled = false;
SerialCmdDone("st13;sc;sf0;sa1;sd70,0,\"INSIDE\";sd127,0,\"OUTSIDE\";sf1;sa0;sd0,12,248,\""
#ifdef FAHRENHEIT
"F"
#else
"C"
#endif
"\";sd0,30,\"%\";sf0;sd0,50,\"g/m\";sd20,46,\"3\";");
SerialPrint("sf1;sa1;sd70,12,\"", C2F(inside.temp), inside.error);
SerialPrint("\";sd70,30,\"", inside.relative, inside.error);
SerialPrint("\";sd70,48,\"", inside.absolute, inside.error);
SerialPrint("\";sd127,12,\"", C2F(outside.temp), outside.error);
SerialPrint("\";sd127,30,\"", outside.relative, outside.error);
SerialPrint("\";sd127,48,\"", outside.absolute, outside.error);
Serial.print("\";");
Serial.print("sf0;sa0;sd0,0,\"");
if (fan) Serial.print("FAN");
else Serial.print("v1.1");
Serial.println("\";sd");
else init_oled = true;
last_time = millis();
delay(1000);
else {
digitalWrite(led, HIGH);
delay(500);
digitalWrite(led, LOW);
delay(500);
init_oled = true;
wdt_reset();
注意:如果您使用 USB 端口对 Arduino Nano 进行编程,则必须将其与IO 扩展器断开,因为它也使用相同的单个串行端口,而不是如果您想调试使用 ICSP 端口对 ATmega328P 进行编程。要启用软件调试端口,请取消注释 SERIAL_DEBUG 定义。
将 110VAC 线连接到两个风扇。
在 PG7 和 PG9 外壳的任一侧钻一个 7/16" 和 9/16" 孔。使用 dremel 工具稍微扩大孔,直到压盖贴合。PG7 将输入 12VDC 输入电压,PG9 将输入传感器和风扇。
找到一个打开且未堵塞的通风口。这将是我们的排气,我们将把地下室/爬行空间的空气吹出。确保另一侧的所有其他通风口都打开,因为这些通风口将成为您的进气口。关闭相邻的通风口,以便在整个地下室/爬行空间中创建区域而不是局部气流。
使用扎带将风扇安装在通风口的内侧。确保风扇指向正确的方向以吹出空气。
找到一个现有的接入点并将外部湿度传感器线穿入内部。确保湿度传感器距离房屋和任何障碍物足够远,以便准确测量环境温度/湿度。根据当地发布的天气报告验证您的读数。
将外部湿度传感器连接到梯形插孔和外壳并将其安装在内部。
将内部湿度传感器连接到梯形插孔和外壳并将其安装在内部。需要额外湿度控制的中心位置或区域是首选。
将 50 英尺 RJ11 电线连接到湿度传感器,并将带有风扇线的电线连接到将安装控制外壳的可用接入点。
连接所有电线并将所有部件组装/送入控制柜。如果您的 50 英尺 RJ11 电线带有预先压接的连接器,您必须将它们切断以将电线穿过压盖并压接新的连接器。
测试系统并确保一切正常。要测试继电器和风扇,请断开 Arduino 与IO 扩展器的连接,并将其直接连接到您的计算机以手动控制它。确认一切正常后,使用双面胶带和包装泡沫将所有部件组装到外壳中以固定您的电路板,并享受智能湿度控制通风系统的好处和节省
在过去几个月在我的爬行空间中运行通风系统后,在我的热水器泄漏后,零挂起和峰值相对湿度大于 95% 后,它已成功将相对湿度降至 50% 以下。通风系统是一个有效的控制系统!
从 SSD1306 0.96" OLED 显示屏切换到 SH1106 1.3" OLED 显示屏。它更大,更容易阅读。使用 IO Expander 固件更新可以轻而易举地改变它。只需在您的代码中将“ST10”更改为“ST13”。
发布了 v1.1,修复了 OLED 显示屏供电空白的冷启动问题。还在为我的爬行空间发泄!
