目录
1.
介绍............................................................................................................................................................. 1
1.1 概述.................................................................................................................................................... 1
1.2 适用性................................................................................................................................................ 1
2.
触控功能说明............................................................................................................................................. 1
3.
SDK 应用架构 ........................................................................................................................................... 2
4.
SDK 资源需求 ........................................................................................................................................... 3
4.1
SDK 占用的硬件资源....................................................................................................................... 3
4.2
SDK 占用的 FLASH&SRAM........................................................................................................... 3
5.
SDK 接口 ................................................................................................................................................... 4
5.1
实时分析处理接口 tsc_alg_analyze_handler()................................................................................. 4
5.2 校准接口 tsc_alg_set_powerdown_calibrate ()................................................................................. 4
5.3 干扰唤醒检查接口 tsc_alg_wakeup_disturb_check()...................................................................... 4
5.4
获取版本接口 tsc_alg_get_version()................................................................................................ 4
5.5 算法计时接口 tsc_alg_tick_count().................................................................................................. 5
5.6 应用获取触控所需 SRAM 大小 tsc_alg_need_sramsize().............................................................. 5
5.7 初始化接口 tsc_alg_init() ................................................................................................................. 5
5.8
启动接口 tsc_alg_start().................................................................................................................... 6
5.9 触控低功耗接口 tsc_alg_set_powerdown()...................................................................................... 6
5.10 回调函数接口 tsc_alg_isr_callback() ................................................................................................ 6
5.11 调试接口 tsc_alg_debug_output() ...................................................................................................... 7
6.
使用指南..................................................................................................................................................... 8
6.1 触控 SDK 操作流程.......................................................................................................................... 8
6.2 应用范例............................................................................................................................................ 9
7.
历史版本................................................................................................................................................... 14
8.
声 明......................................................................................................................................................... 15
