Overview
The need to detect and measure pressure and weight is a very common requirement for modern industrial control and
system monitoring. Pressure measurement is especially important, as it is also used indirectly to measure flow, altitude,
and other properties. Pressure- and weight-measurement devices can be regarded as "force sensors," since force is the
property that affects the transducers' outputs. The applications for force sensors are vast and range from vacuum gauges,
to heavy machinery weigh scales, industrial hydraulic equipment, and manifold absolute pressure (MAP) sensors for
internal-combustion engines. Each application has its own diverse needs for precision, accuracy, and cost.
