The NANDxxGAH0P is an embedded flash memory storage solution with MultiMediaCard™
interface (eMMC™). The eMMC™ was developed for universal low-cost data storage and
communication media. The NANDxxGAH0P is fully compatible with MMC bus and hosts.
The NANDxxGAH0P communications are made through an advanced 13-pin bus. The bus
can be either 1-bit, 4-bit, or 8-bit in width. The device operates in high-speed mode at clock
frequencies equal to or higher than 20 MHz, which is the MMC standard. The
communication protocol is defined as a part of this MMC standard and referred to as
MultiMediaCard mode.
The device is designed to cover a wide area of applications such as smart phones,
cameras, organizers, PDA, digital recorders, MP3 players, pagers, electronic toys, etc. They
feature high performance, low power consumption, low cost and high density.
To meet the requirements of embedded high density storage media and mobile applications,
the NANDxxGAH0P supports both 3.3 V supply voltage (VCC), and 1.8 V/3.3 V input/output
voltage (VCCQ).
