C8051F020
消耗积分:0 | 格式:exe | 大小: | 2011-04-02
zhuyu4839
分享资料个
HIGH SPEED 8051 μC CORE
- Pipe-lined Instruction Architecture; Executes 70% of Instructions in 1 or 2
System Clocks
- Up to 25MIPS Throughput with 25MHz System Clock
- 22 Vectored Interrupt Sources
MEMORY
- 4352 Bytes Internal Data RAM (256 + 4k)
- 64k Bytes In-System Programmable FLASH Program Memory
- External Parallel Data Memory Interface – up to 5Mbytes/sec
DIGITAL PERIPHERALS
- 64 Port I/O; All are 5V tolerant
- Hardware SMBusTM (I2CTM Compatible), SPITM, and Two UART Serial
Ports Available Concurrently
- Programmable 16-bit Counter/Timer Array with 5 Capture/Compare
Modules
- 5 General Purpose 16-bit Counter/Timers
- Dedicated Watch-Dog Timer; Bi-directional Reset
CLOCK SOURCES
- Internal Programmable Oscillator: 2-to-16MHz
- External Oscillator: Crystal, RC, C, or Clock
- Real-Time Clock Mode using Timer 3 or PCA
SUPPLY VOLTAGE ........................ 2.7V to 3.6V
- Typical Operating Current: 10mA @ 25MHz
- Multiple Power Saving Sleep and Shutdown Modes
100-Pin TQFP (64-Pin Version Available)
Temperature Range: –40°C to +85°C
评论(0)
发评论
下载排行榜
