VG54123/VG54123L/VG54123P pdf
消耗积分:10 | 格式:rar | 大小:333 | 2009-03-28
张虎豹
分享资料个
The VG54123 circuit for the amplifying parts of earth leakage circuit breaker consists of differential amplifier, latch circuit and voltage regulator. It is connected to the secondary side of the zero current transformers (ZCT) which detects leakage current in the both input of the differential amplifier. Signals amplified by differential amplifier are integrated by an external capacitor, and connects to the input terminal of latch circuit with output suitable for the characteristics of high-speed earth leakage circuit breaker. Latch circuit keeps low in the output till the input voltage reaches the fixed level, and output becomes high when the leakage current more than fixed flows. It drives a thyristor connected to the output terminal of latch circuit.
评论(1)
发评论
yiminglei 2015-05-18
0 回复 举报
顶一下~~~~~~~~~~~~· 收起回复
下载排行榜
全部1条评论
