基于Linux的上网本音效体验改善设计
消耗积分:0 | 格式:pdf | 大小:166 KB | 2011-04-06
liuxin
分享资料个
The main operating systems (OS) used in netbooks are Windows?XP and Linux-based OS. These
operating systems work best with the low-power CPUs in today抯 netbooks, which are mostly running
Intel?Atom?processors, and offer the best fit for the system requirements, specifications and
configuration of netbooks. Linux enables a lower-cost solution for netbook designers as its royalties are
lower, helping keep the price point low. Linux also uses less system memory, which is required for higher
performance, and is generally much faster than Windows.
评论(0)
发评论
下载排行榜
