GPS码相位和载波相位组合建模
消耗积分:0 | 格式:pdf | 大小:694 KB | 2011-04-12
clp2012bon
分享资料个
  传统GPS定向多采用载波观测量建立观测模型,但其在单历元情况下存在秩亏问题。为避免此问题,文章提出将载波相位和码相位加权后的线性组合用于建立观测模型,在新的GPS定向观测模型中,采用消元处理得到整周模糊度浮点解。实验结果表明该模型可以使整周模糊度浮点解的精度在5周以内,能辅助LAMBDA算法快速确定整周模糊度。
  Abstract:
  GPS carrier observation matrix rank is deficient for single epoch that exists on conventional GPS orientation determination models. The mixed module with both carrier observation and code observation is a way to get a float ambiguity solution module, using weighting, linear plus elimination process. The results of this study indicate the precision of float ambiguity solutions obtained by the mixed module is in 5 cycles, which can quickly help LAMBDA algorithm estimate correct integer ambiguity resolution.
评论(0)
发评论
下载排行榜
