PK2CMD V1.20 PICkit 2 命令行接口说明文件
消耗积分:0 | 格式:zip | 大小:117 KB | 2011-04-25
liuxin
分享资料个
PICkit 2 Command Line Interface (PK2CMD) is a 32-bit command-line interface
to the PICkit 2 device programmer.  This interface is designed for
programming devices in an evironment where batch files or custom controlling
software is desired.
The PK2CMD executable requires the "PK2DeviceFile.dat" file for execution.
This file should be kept in the same directory as the executable.
NOTE: To call pkcmd.exe from other directories and still allow it to find
the device file, the directory where both reside should be added to the
PATH environment variable.
Ex:
评论(0)
发评论
下载排行榜
