Telegram bot 是应用程序编程接口或也称为“API” ,它允许程序员在本教程案例中同时集成两个不同的应用程序,称为带有 ESP8266 的聊天应用程序 Telagram。
由于 TelegramBOT API 令牌的存在,它可以连接在电报聊天和硬件系统之间,例如,它将集成在使用 Arduino IDE 编程的迷你 Wemos D1 与此应用程序之间。
该项目使用了电报机器人 API 和 Wemos,将用于制作智能家居来控制灯和门。
#include
#include
#include
#include
Servo myservo;
char ssid[] = "KAMAR KOS 7"; // your network SSID (name)
char password[] = "dasarlemahkaunak"; // your network key
#define BOTtoken "883873080:AAGkP-oNlzMgOS44X1jhE43C0_9JwwMCBPw" // your Bot Token (Get from Botfather)
WiFiClientSecure client;
UniversalTelegramBot bot(BOTtoken, client);
int Bot_mtbs = 1000; //mean time between scan messages
long Bot_lasttime; //last time messages’ scan has been done
bool Start = false;
const int ledPin1 = 0;
const int ledPin2 = 2;
int ledStatus = 0;
void handleNewMessages(int numNewMessages) {
Serial.print("status pesan = ");
Serial.print(String(numNewMessages));
Serial.println(",pesan berhasil diterima\n");
for (int i=0; i String chat_id = String(bot.messages[i].chat_id);
String text = bot.messages[i].text;
String from_name = bot.messages[i].from_name;
if (from_name == "") from_name = "Guest";
if (text == "/led1on") {
digitalWrite(ledPin1, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(ledPin2, LOW);
ledStatus = 1;
bot.sendMessage(chat_id, "Led 1 is ON", "");
if (text == "/led1off") {
ledStatus = 0;
digitalWrite(ledPin1, LOW); // turn the LED off (LOW is the voltage level)
bot.sendMessage(chat_id, "Led 1 is OFF", "");
if (text == "/led2on") {
digitalWrite(ledPin2, HIGH);
digitalWrite(ledPin1, LOW);// turn the LED on (HIGH is the voltage level)
ledStatus = 1;
bot.sendMessage(chat_id, "Led 2 is ON", "");
if (text == "/led2off") {
ledStatus = 0;
digitalWrite(ledPin2, LOW); // turn the LED off (LOW is the voltage level)
bot.sendMessage(chat_id, "Led 2 is OFF", "");
if (text == "/alloff") {
bot.sendMessage(chat_id, "All led is OFF", "");
if (text == "/allon") {
digitalWrite(ledPin2, HIGH); // turn the LED off (LOW is the voltage level)
bot.sendMessage(chat_id, "All led is ON", "");
if (text == "/rules") {
bot.sendMessage(chat_id, "Perintah yang dapat diproses adalah perintah yang tertera dalam menu /help, Akep_bot juga tidak mentolerir adanya kesalahan pengetikan.","");
if (text == "Akep") {
bot.sendMessage(chat_id, "Hai " + from_name + " aku disini, ketikan /start untuk memulai bot");
if (text == "/status1") {
if(ledStatus){
bot.sendMessage(chat_id, "Led is ON", "");
} else {
bot.sendMessage(chat_id, "Led is OFF", "");
if (text == "/status2") {
if(ledStatus){
} else {
if (text == "/start") {
bot.sendMessage(chat_id,"Selamat datang di Aplikasi Bot Telegram\n hai "+ from_name +", ketikkan /help untuk melihat perintah apa saja yang tersedia pada bot");
if (text == "/help") {
String welcome = "Hai " + from_name + " :) \n";
welcome += "berikut perintah yang tersedia pada bot\n";
welcome += "/rules : aturan memakai bot\n";
welcome += "/led1on : menyalakan led 1\n";
welcome += "/led1off : mematikan led 1\n";
welcome += "/led2on : menyalakan led 2\n";
welcome += "/led2off : mematikan led 2\n";
welcome += "/status1 : cek status led 1\n";
welcome += "/status2 : cek status led 2\n";
welcome += "/allon : menyalakan kedua led\n";
welcome += "/alloff : mematikan kedua led\n";
bot.sendMessage(chat_id, welcome, "Markdown");
void setup() {
Serial.begin(115200);
// Set WiFi to station mode and disconnect from an AP if it was Previously
// connected
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
// attempt to connect to Wifi network:
Serial.print("Connecting Wifi: ");
Serial.println(ssid);
Serial.println("ketikan nama bot anda pada telegram");
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
Serial.print(".");
delay(500);
Serial.println("");
Serial.println("WiFi terhubung");
Serial.print("IP address: ");
Serial.println(WiFi.localIP());
Serial.println("ketikan nama bot anda pada telegram ");
Serial.println("");
pinMode(pir, INPUT);
pinMode(ledPin1, OUTPUT); // initialize digital ledPin as an output.
pinMode(ledPin2, OUTPUT);
delay(10);
digitalWrite(ledPin1, LOW); // initialize pin as off
myservo.attach(12);
myservo.write(180);
void loop() {
if (millis() > Bot_lasttime + Bot_mtbs) {
int numNewMessages = bot.getUpdates(bot.last_message_received + 1);
while(numNewMessages) {
Serial.println("Pesan Diterima");
Serial.println("sedang diproses.....");
handleNewMessages(numNewMessages);
Bot_lasttime = millis();
