This examples shows the usage of External Interrupts on the MCB2100
Board. It uses the EINT1 input assigned to GPIO 0.14 (conntect to
INT1 push button on Keil MCB2100 when jumper INT1 is ON).
The interrupt pin is configured edge sensitive. Whenever you release
the push button a counter is incremented that is output to the LED's
conntected to GPIO 1.16 - 1.23.
全部1条评论
