W79E633v01 Datasheet
消耗积分:0 | 格式:pdf | 大小:661 KB | 2011-05-09
分享资料个
The W79E633 is a fast, 8051/52-compatible microcontroller with a redesigned processor core that
eliminates wasted clock and memory cycles. Typically, the W79E633 executes instructions 1.5 to 3
times faster than that of the traditional 8051/52, depending on the type of instruction, and the overall
performance is about 2.5 times better at the same crystal speed. As a result, with the fully-static
CMOS design, the W79E633 can accomplish the same throughput with a lower clock speed, reducing
power consumption.
评论(0)
发评论
下载排行榜
