索尼KV-21FE12彩电电路原理图
消耗积分:0 | 格式:pdf | 大小:10.4 MB | 2011-05-30
分享资料个
本内容向大家提供了索尼KV-21FE12彩电电路原理图
The units in this manual contain a self-diagnostic function. If an error occurs, the STANDBY/TIMER LED will automatically begin to flash.
The number of times the LED flashes translates to a probable source of the problem. A definition of the STANDBY/TIMER LED flash
indicators is listed in the instruction manual for the user’s knowledge and reference. If an error symptom cannot be reproduced, the Remote
Commander can be used to review the failure occurrence data stored in memory to reveal past problems and how often these problems occur
评论(1)
发评论
lao369258 2011-11-03
0 回复 举报
收起回复
下载排行榜
全部1条评论
