SL811HS VxWorks Host Driver Release Notes
The SL811HS is a dual role host / slave embedded USB device. The SL811HS VxWorks Host Driver integrates the
SL811HS into the VxWorks USB host stack, providing a complete embedded host solution for this operating
system. Please refer to the User’s Guide for detailed information.
Description
The structure for this release contains the following files:
In the Docs directory:
· SL811HS VxWorks Host Driver Release Notes v1.0.doc – This document
· SL811HS VxWorks Driver Errata.pdf
· SL811HS VxWorks Driver User Guide.pdf – Setup environment, installation instruction, etc
