SL811HS/SL811S pdf datasheet (
消耗积分:5 | 格式:rar | 大小:333 | 2009-04-14
哈哈哈
分享资料个
The SL811HS generates erroneous packets after it tries to communicate with low speed
devices through USB Hub.
In some instances when operating with low speed devices attached to a Hub, the
SL811HS fails to switch back to Full Speed at the end of packet time (EOP). This
results in the next tokens being transmitted erroneously at Low Speed.
“Erroneous packets” are low speed token packets,“3C”. The SL811HS starts
generating them after sending a low speed ACK over USB Hub. This problem occurs for
low speed PID_IN transactions only.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
