Note5148为Skype长距离扬声器和电视应用的设备配置
消耗积分:0 | 格式:pdf | 大小:141 KB | 2011-10-19
王自锋
分享资料个
Abstract: The MAX9860 audio voice codec provides an ideal solution for Skype® long-range audio-capture applications and enables high-quality voice transmission. Target applicationsinclude Skype for TV, set-top boxes, and speakerphones. By providing a flexible range of programmable gain settings and accepting sample rates up to 48kHz, the MAX9860 amplifiesanalog microphone signals and converts them to digital audio with performance in mind. In addition, the MAX9860's two microphone inputs allow the application to record from a twomicrophoneor four-microphone array using a beamforming algorithm for directional sensitivity and noise cancellation.
评论(0)
发评论
下载排行榜
