lpc2300代码,源程序包
消耗积分:10 | 格式:rar | 大小:333 | 2009-04-18
王娟
分享资料个
lpc2300代码,源程序包: *   readme.txt:  Description of the LPC23xx Example Software Package
 *   Copyright(C) 2006, NXP Semiconductor
 *   All rights reserved.
 *   History
 *   2006.09.01  ver 1.00    Preliminary version, first Release
 *   2006.11.30  ver 1.10    Release 1. In this release, the major change
 *                           including:
 *                           (1) "lpc230x.h" has been changed to "lpc23xx.h"
 *                           to match the description.
 *                           (2) Tested on the latest Keil IDE 3.03a which has
 *                           the LPC236x device in the database, the beta release
 *                           used "LPC214x" for debugger and flash utility.
 *                           (3) Added I2S example.
 *                           (4) Hardware chage in Enable Control in port LCD.
 *                           (5) Fixed USB clock enable bit hangs caused by the
 *                           bootloader change.
评论(1)
发评论
evan_henry 2016-10-21
0 回复 举报
驱动挺全的。 收起回复
下载排行榜
全部1条评论
