CT7602 Audio USB Bridge
消耗积分:0 | 格式:pdf | 大小:256.82 KB | 2024-01-04
深圳市汇能远科技有限公司
  • 173内容
  • 35w+阅读
  • 1.1k粉丝
CT7602 Audio USB Bridge : True 32 bits 768KHz
Key Features:
1 playback port, and 1 record port
       PLAY: 2-channel I2S, 2-channel DSD, 2-channel SPDIF
       RECORD: 2-channel I2S, 2-channel DSD
       The clock systems are independent
 I2S Interface
     PLAY port supports standard/left justified format, master mode.
     RECORD port supports standard/left justified, master/slave mode.
 Audio transmission
    PCM support up to 768K/32bit through USB, I2S, SPDIF ports.
    DSD (PDM) support 1x/2x/4x/8x bandwidth through DSD(PDM) port.
    DSD (Native) support 1x/2x/4x/8x bandwidth through USB, I2S, DSD(PDM) , SPDIF ports.
    DoP support 1x/2x/4x bandwidth through USB, I2S, SPDIF ports.
Interface
          Up to 16 GPIOs configurable as input or output.
          Master / Slave I2C interface.
          3 PWM-LED.
Format auto detecting
          Auto detecting PCM / DoP format.
          Auto detecting I2S / DSD interface.
Misc
          UART interface
          Volume control with fading in/out function.
          Playback basic auto De-pop function.
          One 12MHz crystal requirement only.
          Digital MIC input acceptable.
          2 External OSC select for output PLL
评论(0)
发评论
下载排行榜
